I'm working on my 1999 S150TXRX PTT not working problem. I screwed in the pressure release bolt on the port side of motor and when I use either the control PTT or motor PTT I just get a clicking sound. So I'm thinking solenoid or relay.
On port side of motor there are 3 assemblies with electrical connectors on them which I believe are relays, the top two seem to be related to the PTT and the bottom one appears to be a starter relay, is this correct?
Using a Yamaha service manual I should be getting continuity from:
Lt Grn to Blk I'm getting no continuity
Sky Blu to #1 post I'm getting no continuity
Lt Grn to #1 post I'm getting no continuity
Every other part of the testing procedure when I'm suppose to get continuity or not are good.
So I'm assuming the relay is bad, is that correct?
My last question is if I am correct so far do I replace the top two relays together or just the top relay?
