Re: pulling ehaust manifold to replace gasket, do need to winterize?
Sorry for the lame post. I have a 470 with an alpha drive. The exhaust gasket has been leaking, I've been adding antifreeze each time I take it out. I have to change the gasket. So I will be taking off the exhaust manifold and heat exchanger when I change the gasket. I plan on pulling the outdrive to check/replace the impellor and check/replace the gimbal bearing. So yes, my question is if I do all this before winter, do I need to run antifreeze through the system? I think spdracr39 answered my question.... all the water may not drain from the block...
