Augoose
- Mar 21, 2010
- 1,223
Re: Question about a possible upcoming purchase - ford 2.3 cyl w/ problem
The owner did state that the problem with the distributor was burned points, so I'm planning on replacing that as well as the coil (which he already has a new coil, just not installed yet) . I guess that somewhere along the way he or someone else had a non OEM ignition component (condenser, voltage regulator, etc) that didn't send the proper voltage to the distributor. Sound about right?
You might pull the distributor and have it checked out by an auto electric shop. "Distributor" problems can be anything from a bad coil to burned points or a bad ground.
