Re: Remove motor from boat
If you get a cheap harmonic balancer removal tool,put a lifting eye where the center bolt goes,then get 3 bolts that screw into the holes in the flywheenl that are used for lifting and removing the flywheel,you will be in business for about 25 bucks,Be sure to get hardened bolts and tighten enough to remove all play.Or try ebay under motor acessories/tools
