Replace OMC 3.0 with Mercruiser 3.0
robcurtiss
I have a 1988 OMC 3.0L with a lovely crack along the block. When looking for a replacement, can I use a Mercruiser 3.0 instead? What is the difference in the engine that would not allow this transplant?
Re: Replace OMC 3.0 with Mercruiser 3.0
Ayuh,.... Everything bolted to it after it gets to the "Long Block" configuration... google it if ya don't know...
cr2k
Like Bond-o said it the same engine except for the OMC specific bolt ons.
robcurtiss
The engine was running great until I failed to properly winterize and the block cracked. If the long block is the same, then I have no troubles moving the intake/exhaust/accessories as needed from the broken motor. Thanks for the info!
