bajaunderground
- Apr 18, 2008
- 1,401
Hey fellow boaters...we had a gorgeous day here in Colorado (perfect for Fall boating) I thought I'd replace the bellows in my signature boat. Having never done this before it most likely took me a little longer than the experts...but I saved a grip of money in the process! So Here's the play-by-play of what I did. Standard Disclosure: I replaced the drive and exhaust bellows in my Volvo Penta SX out drive following various posts' advice, OMC manual and common sense. I take zero responsibility if you follow my steps and screw it up. The only special tool I needed were snap-ring pliers and a 1/2 hex socket for a 1/2 drive (readily available at Autozone). The snap-ring pliers I got a Ace Hardward, but were too small to reach...so I improvised and used needle nose pliers.
Enjoy!
First couple of pics is of the drive and removal of shift linkage covers.
Detach shifting cable from shifting arm; then unthread it from shifting cable.
remove and support hydraulic rams, 5/8" wrench and socket (I think support is not really necessary, as they can hang relatively easily and safely. Use you best judgement when removing rams?)
Loosen the 6 nyloc 7/16 x 20 bolts holding the drive to pivot housing. (most recommend replacement...use your best judgement?) I do not envy you salt water boating peeps...these is strictly a fresh water out drive u-joints. Extremely clean!
Next post....
Enjoy!
Next post....
