RatherBFishing
- Sep 11, 2003
- 39
I have a '91 Mariner V200, S#0D038776. I was seeing a little oil from the front ports while it was sitting. Based on the Marine Doctor's recommendation, I am planning to replace the shift shaft seal. I pulled the lower unit and it looks like he was right. The only oil showing anywhere was right there where the shift shaft and the speedo pickup is. When I drained the oil, no water seemed to come out so I assume it must not have been leaking too bad, but better to fix it now than when it does cause problems. Now I just need to find the parts. While I am at it, I am going to replace the impeller. I was looking at a couple sites and I can't figure out which parts to buy. My serial number listed above there does not seem to fall into the ranges they list, unless I am reading them wrong. The range I think it would fall into on the sites start with D082000. At least that is the only one that I see that starts with D. Anyway, does anyone know a good place to buy the parts and which parts I need? I assume I can get the impeller as a kit. The shift shaft seal I am not sure about. I suspect I need a special tool for that too.<br /><br />Thanks!<br />Mike
