Required outboard Cranking Amps...
Joseignacio
I purchased a boat with a 150 HP Mercury. According to the manual, it requires a 650 Cold Cranking Amps battery. The boat currently have a 1000 Cold Cranking Amps battery. Will this bigger battery affect the motor or electrical system ??
daveswaves
Ensign
Re: Required outboard Cranking Amps...
No you will be fine, the 650 is the minimum needed or recommended, does not hurt to have extra capacity.
