Re: Retarding timing to gain wot rpms
I read a statement on another site that said retarding the timing will increase wot rpms. I want to find out if anyone else has heard of this. Obviously timing advances with the throttle. And my timing is 26? at cranking speed, which in the water should translate to 28?. A little more background. I had rebuilt the carbs, replaced fuel lines from fuel tank all the way to the carbs,new starter, New solenoid, New battery and wired it for duel batteries, New bosien power reeds, new spark plugs, and wires, pulled the flywheel checked the shear pin, cleaned the magnets on the flywheel, pulled the jet replaced the o rings checked the impellar for nicks, changed the gear fluid. Short of rebuilding the motor I wanted to see if I missed something simple. So it's a little more than a whim. I might be stubborn but I have found everything I would need to rebuild the motor. So whether it's new to me or not there is no reason this motor should not hit its factory specs.
