Re: Retarding timing to gain wot rpms
I appreciate you answering my post but it's apparent that you want to get into a pissing contest and I would like to pass on that. Im only looking for advice or constructive opinions nothing else.
You are entitled to your opinion, and I am sorry if you feel that anything I said was confrontational.
If I think have anything to contribute to one of these problems, I will weigh in, but I will confess that it can be a bit irritating when someone who comes in here looking for assistance ignores questions that might help widen the search for the problem, and then dumps on someone who is legitimately trying to help.
You have to keep in mind that you are the only one who has first-hand access to the problem...and symptoms.
We have to try and assess anything based on your info, and try to sense your level of competence....and do it in in typeable bits.
And with all due respect, the following two statements from you are contradictory, and that is why I questioned your understanding of ignition timing....which may be why you took offense.
You can not set the timing to exactly 28? while cranking the motor because it is not the same as the motor running at wot. It should be 2-4 degrees less. Then checked on the water with a load on the motor. So 26? at cranking speed should translate to 28? on the water with a load on the motor.
From what I understand and I could be wrong but timing retards a little naturally at wot. Thanks for all the replies.
It would still, IMO, be worth your time to weigh the whole rig and compare it to OEM spec.
