- Jul 18, 2011
- 18,562
I guess because raising up the elbows with spacers slightly changes the angles of how the down pipes match up to the Y pipe....
I think the angle will be OK, as the 'down elbow' ends up being mostly vertical going into the Y-pipe.
My bad was not measuring the circumference correctly on the down elbow/Y-pipe . . . I used the coupler and took a rough measurement of 3.5", and figured it must be designed for such.
Now having the fit issue, I measured the down elbow more closely and got a circumference of 11.8", which then calculates to a diameter of 3.75"
The 3.5" diameter tube, having about an 11" circumference would need to stretch over 3/4" to fit . . . which it was not going to do.
I have 3.75" ID 'flex' tube on order, hopefully it gets here soon.
