Scott06
- Apr 20, 2014
- 7,377
Had carb apart .adjusted float and so on. The accelator pump doesn't shoot gas everytime I pump it. Also has bog. It's a new cup and spring on it. The check ball is in the well...at a loss here
There is a ball down stream of the pump that can get left out if you take the venturi cluster out. Would suspect either this ball the check ball in the pump well ( they are two different sizes so can get mixed up) or the spring are not in the right orientation.
I feel your pain as have been there and done that, not trying to be a jerk but it seems when you have taken it apart it hasn't gone back together right. Same could happen with the holley ... or if it does not work perfect out of the box. A 2 jet is about as simple as they come ...I'm done with this carb
