Saftey Gas Cans - Messy Frustration
gtochris
Re: Saftey Gas Cans - Messy Frustration
I Prefer the new "safety" can as I can get the can tipped and into the nozzle then push the button, our other older can it is a struggle to make this transition before it starts pouring out and I accidently got the back of the boat a little last night:(
The_Kid
I am about to drill a small vent hole in mine, then plug with a wood screw. If it doesn't work, I can seal it.
I added a vent to mine using a metal tire valve stem minus the valve. Drilled a hole at the rear of the handle the right size, fed a string in the hole and fished it back out the spout hole. Feed the string through the valve stem and tie a small nut on the end of the string. Pull the string back through the hole and secure with the nut.
You can also buy the old style non C.A.R.B. spouts here.
