kenny nunez
- Jun 20, 2017
- 3,483
2Xs with Scott06. I have had a leak from one of the rubber exhaust hoses , with the engine running wrap your hand around the rear of the pipe below the clamps.
If an Alpha drive, The raw water hose from the transom to the engine cooling system may be leaking at the transom fitting or the hose itself, since the raw water pump is in the drive lower unit. But the Y pipe would leak all the time, since it is below the water line.No just when engine running.
