Re: Sending unit
stemar,<br /><br />All you need is some tubing and a "tee". <br /><br />The tuibing inside diameter should be the same size as the outside diameter of the nipple on the back of the guage. <br /><br />Then, you will need a 3-way tee to tie into the telltale line on the engine. An automotive vacuum line tee will work fine for this as well as automotive vacuum hose.<br /><br />The tell tale, on the back of the engine has a discharge line going from the cylinder head to the outlet. Simply cut and splice the tee into that line. The open end of the tee goes to the guage.
