service manual question
hardwater fisherman
my question is that i have 2 1976 40 hp outboards. one is a johnson electric start short shaft. the other is an evinrude rope start long shaft. if i buy a manual for my evinrude will it also cover the johnson? im converting the evinrude to electric start using the parts from the johnson. thanks in advance.
Bob_VT
Re: service manual question
Yes. they are the same manual............
hardwater fisherman
ok thanks. do you think it will be helpful? some of the wires are cut and i need to install a key or push button.
Bob_VT
Yes the wiring diagram will help you out. Now I would also suggest a real shop manual. Here is a great OEM shop manual supplier http://www.outboardbooks.com
