Shift cable for omc
Howard Sterndrive
Re: Shift cable for omc
Industrial electricians use a heatless shrink covering on large electrical cabling. You slip it over into position and then pull a nylon thread out. As the thread pulls out (seems like there's miles of it inside) the tubing shrinks down tight.
There's also heat shrink tape - wrap it on like tape, then shrink-seal it with a heat gun.
There is also those kits to make your own custom hoses. I think it kind of works the same way... not familiar with it though. Summit racing or somewhere like that might have that stuff.
JustaLawnGuy
Great idea all, and thanks for the help, I went today and got some its from the City(my dads work) they use it for the cables in the water plant. The only problem is I took the cable out of the housing and the cut starts right at the end of the cable. I cleaned it all up and apply this heat shrink with a hot air gun and it seems that on the cable its holding but when you tighten it down back to the housing its not sealing there, I am going to wait for this I am assuming it like liquid tape, thick black stuff like bull to dry more and I might as well just seal the whole end, bolts and all. thanks for all the help, But I am still looking for an replacement in the meantime
JustaLawnGuy
JustaLawnGuy
I got to ask, I do have an hydro-mechanical shifting unit, right?
JustaLawnGuy
Malibud
i epoxyed mine and has worked so far we will see doug russsel has them for 450$ i am ready to sell mine a malibu w/ 800 w/ 300 hours
JustaLawnGuy
Thanks again
I have mine drying right now and cross my fingers all is well. I think the heat shrink was the best idea, it looks. going to let it sit overnight before I mess with it again. before I button it all up I will test and see if it leaks..
I am ok with buying this boat, like to work on it in a way, that way I know what I have but finding the parts is like pulling teeth with pliers. will look into changing out the unit. soon
JustaLawnGuy
