shift spool replacement
chris650
Re: shift spool replacement
it opened BT. But is that the right manual for a 1978? In the contents I didn't see my outdrive model. I have an mc-1. Or are they all fairly similar?
chris650
sorry if I didn't mention that before...my bad
Bt Doctur
Should work just fine. The MC1,R,MR,Alpha are very close. water pump base is different on the mc1, preload pin and no preload pin have differences
chris650
ok, thank you very much! I guess I will start by checking that shift shaft play and take it from there.
chris650
Just for reference, how should the racheting tension feel that I was referring to? Should it take some amount of force to get the prop to rachet, or should it coast a little?
achris
More fish than mountain goat
Needs a bit of force to turn. You should not be able to 'flick' the prop over the ramps...
