SkegShield?
hostage
I lost my skeg a couple weeks ago and I was told I could weld a new one on. I also heard that I could get a skegshield.
http://www.iboats.com/Skeggard-Repa...68086712--**********.156250824--view_id.39561
Anyone have any luck with these or try them before? It looks like it might work if I happen to have enough left of my original skeg. They are made of Staineless Steel, I hear when it comes to props it is better to have a broken prop then a broken lower unit, I don't know if it is the same with the skeg.
Thanks,
Hostage
oops!
Re: SkegShield?
you can weld them on....
however....if done incorrectly.....it will melt the seals an you will need a re seal.
the skeg gaurd is an exellent option, and iboats is an exellent store.
Bob_VT
Re: SkegShield?
I have used one in the past and it just bolted on..... after you drill a few holes.
I have also made my own from Stainless Steel in the past.
They work fine and fast to install w/o any welding needs.
hostage
Re: SkegShield?
Already bought a Bimini from them, I guess information from this site is worth my blind loyalty. I know they have saved me a lot of money already.
I will have to see if I have enough skeg left to use a replacement like this. In any case what is the going rate to have one re-welded on? If I have to take the lower unit off, I might as well do it when I replace the bellows and impeller this year.
-Hostage
Bob_VT
Re: SkegShield?
If you purchase the skeguard...... you can install it..... if you need a replacement skeg welded then the going rate is probably $75-$100 (on average).
PLEASE find a real good welder with aluminum experience or it could cook your seals and do more harm.
Thajeffski
Master Chief Petty Officer
Re: SkegShield?
it saved my skeg last year, the shield is allll bent up, havent fixed it yet!!
