Thanks for the input silvertip. This is driving me a bit up the wall.
At this point I'm trying to just get it into the rpm range suggested by evinrude. The problem is, their 13.75 x 13 isn't cupped and their 13.5 x 15 is cupped. That puts the motor 800 rpms away from prop to prop. I am disappointed that evinrude doesn't have either a 13.75 15 or a 13.5 13. Or at least they could have made them cupped or uncupped. A bone head move by evinrude if you ask me. There is nothing in between. The boat has been in the water a total or 5 days this year and my brother just washed it yesterday, I just restored the boat including floatation (closed cell), transom, floors, console supports, seat bottoms, etc. and new paint. The motor has no error codes on the computer and it leaves super hard with either prop. The 13 pitch brings it to 6000 and the 15 cupped brings it to 5200. I really just need a prop that is somewhere In between these two. To tell you the truth, there should be two props inbetween these. An 800 rpm drop from evinrude 765181 to 765182 isn't exceptable. From what I was told yesterday by a prop guy is that these etecs and the large gear cases, he is finding that the gearing isn't enough. He said the problem is if I want an etec, I need to be real close to the Max hp range of the boat, which is 90. The lake is a 40 hp max so... he said the older 40's have a smaller lower unit with, i guess higher gearing, and that they will run circles around my etec.
