Starcraft Parts
dozerII
Re: Starcraft Parts
I have the surround bow rail from my 1972 SS180 if anyone is interested. I love it, but I need that area for a trolling motor, which is a must. I don't know how I would be able to ship it, so it would have to be picked up.
I had the same bow rail on my 18SS I just cut the bow rail in front of the center mounts about 6"to allow room for the bow-mount then put in a couple of bullet end plugs. It looks real good and keeps the bow rail.
If you look past the fat guy holding the perch you can see how I cut them and used the bullets
jbcurt00
Re: Starcraft Parts
Is that the trim piece the goes under the motor clamp? I seem to remember someone found some channel that worked, but not an exact replacement.
Watermann @ his Sea Nymph resto:
I remembered when doing the dry fit on the PT unit that my transom cap was mangled, cracked and in 2 pieces.
I had to come up with a new cap so I put my thinking cap on and invited my resto buddy over to help me think. This is what I came up with:
Material I used was 1/16th" aluminum stock. With the transom wood in place and secured, we laid the aluminum down on top, started the bend cold and secured it with screws in the middle. Then we applied heat with a torch and used a round steel bar and rolled it downward to create the bend. Once the flat piece was bent it fit nice and tight, then it was secured with screws above the bend and below. Then came the tricky part, heating the aluminum up just right while using a hammer to slowly bang the bend into the aluminum over the edge. There was some smoke from the transom wood so I suggest if someone tries this to do it before the transom wood is all done up.
Cost 18 bucks.
concept10
Re: Starcraft Parts
Thats an idea that I have pondered lately. I've also been thinking about those short bow rails on the 1987 SS you finished last year. Have'nt made up my mind yet.
As far as the transom cap goes, those are both great ideas that I could try. Thanks guys!
jjacobs007
Re: Starcraft Parts
]I've got a pair of transom caps from my MC that look almost identical to the ones on my Mariner if anyone is looking for some.
I WOULD LIKE TO SEE A PIC OF THE TRANSOM CAPS PLEASE.i HAVE A 18FT MARINER AND IM MISSING THE STARBOARD
ONE.
vettenuts
Re: Starcraft Parts
I have a pair of nice transom caps. Came off of a 1965 Bahama. I can provide better photos if needed. These are solid with no cracks.
bob johnson
Re: Starcraft Parts
i am stripping an islander and will make it an open bow side console....right now i am pulling all the hardware for the cabin, the console, the side panels, trim inside....all the railing on the top of the cuddy the glass, you name it.....its going.....controls and cable( dont know how good the cables are.....anyhting off a 165 mercruiser(going bye bye) metal gas tanks( decent)
anyone interested?
bob
grzzzz
Re: Starcraft Parts
I have a complete, TOTALLY rebuilt, 120 Chevy/mercruiser. I has only about 5-8 hours on it. It is in Santa Fe, NM. Not sure how we connect without violating the posting rules.
Grzzzz
GA_Boater
Re: Starcraft Parts
Grzzzz
Through PMs. If someone is looking, they should PM you. Then no running afoul of the law according to Judge Dredd.
Stephenatx
Re: Starcraft Parts
Concept10 - I guess you decided to hold on to your bow rails?
mattcap9
Re: Starcraft Parts
Ok. I've had zero luck with a w/s for my star chief. Any suggestions?
petraciara
Re: Starcraft Parts
anyone interested?
bob
Woulld the top windshield fit my 1972 starcraft starchief? and the front windshield?
bob johnson
Re: Starcraft Parts
I cant answer...the front windshield in mine was plastic and I threw it out....it was cracked.. the top is glass and in VG shape. youll have to ask others if the top windshield will fit a starcheif bob
North Beach
Re: Starcraft Parts
Why don't you guys just do a little measuring and trade info?
tgp***
Re: Starcraft Parts
I'm looking for a side mount, fold down seat bracket from an islander, I have one with a broken arm.
