Put a new perm magnet starter in my 2.5L 120hp last fall and only used it 3 times since. The stater seems to start out ok and then it will grind, like it is not engaging fully onto the flywheel. It also sometimes runs on with the key off for a couple of moments, usually only after it starts to make grinding noises. I pulled the starter and the starter teeth look good and the flywheel looked ok also. I did notice the flywheel was shinny on the first 1/4 of the teeth leading my to believe the starter is not engaging all the way. I never had any starting problems with my old oem brick starter. Any suggestions??
