Re: Still confused. Love everyone who helps.
You have a Gen+ engine and a Gen II drive.
Splitting the drive, (no special tools needed) easy. #1. Drain the oil! If you have already pulled the drive off the bellhousing, then set it on a stand. Remove the anode above the propeller, use a 3/8" drive 1/2" socket on an extension in through the access hole at the end of the drive. Once that's removed, look up into the cavity it exposed, you'll see another screw. Use a 9/16" socket and remove that. Also remove the nut at the very front of the drive (right next the the shift shaft seal you're about to replace) using a 5/8" spanner or socket (your choice). Then, using 2 x 5/8" spanners, remove the 4 nuts and bolts holding the halves together. lift the top half off the bottom... Yes there will be a lot of oil dropping down, that's normal for Gen II drives.
Once you have the drive split, have a look at the shift shaft at the front of the lower half. It's only held in with a couple of small screws (M6). Remove them and CAREFULLY lift the seal holder and the shaft shaft out of the cavity, making note of the direction the shaft is pointing (I always put the drive in forward so I know the shaft faces directly forward for when I refit it). Once that's all out DO NOT move the gear-housing, prop shaft or drive shaft until you get the new seal in and the shift shaft back in place.
Putting the new seal in is the reverse procedure of removing it... This all sounds intimidating, but it's actually quite easy.... I would replace the entire bushing and seal assembly, with new 'O' rings. Part number you need for that is 23-815921A20 (it's only $21)
'Top end service' is mostly just checking stuff, making sure everything is where it should be and nothing obviously wrong. Check the uni-joints for movement and run the gimbal bearing with your fingers to make sure it's still turning smoothly. Squeeze a bit of grease through to it. Check the engine alignment (you will need an alignment tool for that, go to ebay), have a look at the alignment videos in the 'Adults only' Section...
While you have the drive split, might as well service the water pump. As per the manual, and you do need to use the alignment pins to put the water pump housing back on... I know a lot of people don't bother, but they are the ones who come running back here with 'my engine's overheating'.... :facepalm:
Re-assemble the 2 halves (paying attention to the quad seal that seals the oil passage between the 2 halves, right next to the water pump), fill it with Quicksilver High Performance Gear lube (from the bottom up!), slap it all back on the boat with new gaskets and 'O' rings.... happy for another 3 years...
Here's the video of me putting the drive back on ->
http://youtu.be/aGVrY4cWiDA
Chris..........
If you don't have the service manual I seriously suggest you download this ->
https://docs.google.com/viewer?a=v&...YWRiNy00ODUyLWFmNzgtMTBmMzhlNGY4Mzk3&hl=en_US
