bluebear57
- Mar 12, 2011
- 76
my 87 marnier150 mag is still having low end starting and idling probs when it starts in fast idle on high will only tach about 2000 normally it would race way up sometimes it will start and idle for a few minutes then it sounds like it loses power and will slowly die once it is started and you quickly give it throttle it runs great witout a miss when i first bought the boat the high end of the stater was bad and i had the opposite problem i have good compression rebuilt carbs and new plugs with no change could it be the idle module or the low end of the stater and how can i test them thanks very much
