Stuck Fuel Guage
2twodogs
My fuel guage shows 3/4 full no matter how much gas is in tank. Can anyone advise me where to start looking for the problem. My boat is a 1988 Princecraft 176 Super Pro.
alldodge
Agree
Start with doing some checks to verify, with ignition ON
At the tank sender ground the sender terminal, gauge should peg full
Remove the wire from the tank sender terminal, gauge should peg empty
If neither have any effect go to the fuel gauge and check for 12V to the gauge and a good ground.
Then find sender wire and gauge should show full/empty if the sender wire is grounded/open as tank sender
2twodogs
Thanks for the replies. Will I need to pull the floor out of the boat to get this?
alldodge
In that case start at the gauge, could be the gauge is bad and not the sender
garbageguy
Yes, start with the checks described above.
Regarding your next question
Sometimes you can get at the sender under the floor through the engine compartment, or possibly a small hatch or deck plate installed to access the sender
