Re: stuck steering 40hp johnson
ok let me clarify something cause im comfused now, the stering cable attaches to my motor on the starboard side,,,i undid the cable on the starboard side,,it can be buled in a n out wen u manually move the engine. on the port side theres that arm that goes from the end of the rod to the motor, which is what moves it. i undid that arm from the port side an then took ouot the large nut on the port side,,, should it come out,,,do i need to hit it on the port or starboard side? also the rod is almost all the way in on the port side, theres about an inch of rod coming out. <br /><br />please bare with me as i know very little to nothing about boats. <br /><br />also, if i remove the large nut on the starboard side identical to the one on the port side, and somehow pull everything out will the motor fall off the boat? thats the last thing i want, if i take the boat to a boat shop how much will it run for them to fix something like this,,,this boat is old an not really worth investing too much money on it, i jsut want it to get some practice on boating so wen i do buy a new one i dont wreck it with inexperience,<br /><br />in conclusion,,, i need to know how to get that darn thing unstuck, do i need to remove that large nut on the starboard side an does that steering cable come all the way out? should i disconnect it from the steering side? can i disconect it from the steering side?and do i hammer it from the port or starboard side?
