rogerwa
- Nov 29, 2000
- 2,339
I have a basement that needs some supplemental heating. It has forced air ducts, but gets pretty cold for a couple of reasons..
1) On warmer days the furnace does not run as much because it is warmer upstairs where the thermostat is and the heat rises from the basement.
2) On colder days, It is warmer due to longer running of the furnace, yet it does not get as warm as upstairs. It is not a matter of controlling the vents as I have already done that.
So I am looking to add some supplemental heating that can be controlled separately to use the basement as its own zone, if you will.. I also want it to be fairly cheap..
Here are the options I have looked at..
1) Gas fired firplace insert (there is a fireplace in the basement) - Could be controlled via a remote and would be pretty economical to run and nice appearance - This is my favorite, yet over my desired budget (Minimum ~$1400-1600)
2) Blue flame wall hung vent free heater - cost effective operation, inexpensive to purchase/install - Not so attractive - Poor WAF (wife acceptance factor)
3) Hydronic Electric Baseboard heat - Easy and inexpensive to install - Not sure of expense to run - OK WAF
My question is, does anyone have experience with the hydronic Electric BB heaters - are they more efficient that the standard BB heaters?
I am not thrilled about using electric heat as it tends to be very expensive -but if the Hydronic units add a measure of efficiency, that may be the right solution.
Did I miss any options?? My basement is 27' long x 12.5' wide and has another connected space that is 12x9.
