Turning Idle air screw (hose connected) in either direction does not change engine speed. With hose disconnected can adjust idle speed. Dealer hooked to Suzuki program in his computer and confirmed turning screw (hose connected) had no effect. Dealer stated the program did not allow him to check IAC or voltage further. Dealer suggested I install new IAC valve. Installing same, no change. My ques, how can I safely check the voltage going to IAC valve? What is correct voltage? If a wire is broke can I find that wire? Can I check the IAC valve I removed by probing the 2 contacts and what should I be looking for or reading? I'm convinced the problem is in voltage or ? controlling the IAC valve. Thanks
