Re: Symptoms of water jacket leak?
Service school taught that any silicon based sealer could cause a leakage and most silicons wont hold up to heat in this area anyway,that why resiweld is called for instead of loctite on bolts as it good to about 400?
I just went out to the shop and got a new tube of Permatex Blue RTV Silicone "Gasket Maker" it's called. On the rear of the package it comes in it says "Temperature range: -65F to 500F". That ought to cover it.
But really man, you are talking about a rather thin aluminum (3rd best heat/cooling/electric current conductor) that has exhaust on one side and 140 to 190F (worst case) water on the other. It ain't a gonna see any 400F...maybe 200 and that's a walk in the park.
I don't have any of that stuff you called for but I do have 3 different grades of Locktite, including blue #220 for removable fastners and I also have a couple little packets of Thread-Magic Anti-Seize that they sell for your spark plug threads at the auto parts store...(where I got the RTV). On the package it says it is also used for "Head Bolts, Alternator Bolts, Starter Bolts, Water Pump bolts". The screws are screwed into the block and it too MAY see 200F. That ought to cover it.
Looks like we are good to go. I guess Merc Man can make up his own mind. We did what we can do for him.
Mark
