Re: Synthetic oil use?
A purchase of synthetic oil is similar to buying an insurance policy
in case your engine should be subjected to extreme usage.
If any number of circumstances were to subject your engine to a
heavier work load, it will work harder, and create more heat in the
process. Assuming your cooling system has anti-freeze and will not
break down, the other consideration is keeping your engine lubrication
system working. Synthetic oil will hold up under higher temperatures,
where regular oil is more likely to break down under higher temperatures.
I used synthetic oil for pulling a trailer across the mountains with a
6 cylinder pick-up truck, and it saved my engine. I would not repeat
that experience of watching the temp gauge at high and wondering
when the engine would go. It made it through that trip, and several
more years. I have not used synthetic oil in my boats, and have no
intentions of doing that. Extreme use on a boat would be trying to
pull a bigger boat at too fast of a speed, and I won't do that. I do
use 20w-50 oil, changed each year.
It's your call!
