Ive had a 2002 and a 2005 vehicle that stuck closed recently. Never heard of a stat built to fail open, its a good idea though.
almost never on boatsSeeing, reading, and hearing all of the problems associated with overheating, due in many cases to faulty T-stats.
You can make your own over-temp alarm.
Here is what I did:
http://forums.iboats.com/showthread.php?t=478660&highlight=temp
The main component is the temp switch.
I don't believe oil pressure alarm is that necessary.....just my opinion.
If this is for the 165, there MIGHT be a hole in the water pump, but otherwise, yeah bang another port in the thermostat housing....
Which is very obnoxious by the way. I want to design one and build one that has my stupid drunken ex-wife yelling the faults at me!... No probably not a good idea if I have any weapons around.Yes, but the oil pressure switch will fire the alarm every time you turn the key on to start the engine... An EXCELLENT self-test of the system... You hear the alarm, you know it's working....
