tachometer problem-1995 evinrude 88 spl
dieselcat
I recently installed this motor on my boat and just bought the tach wiring harness.I installed the harness, started the motor and rpm gauge does not work.i tested the purple and grey wires with test light,the purple works but grey does not.i tested the grey wire coming from stator soon as motor starts test light,lights up.i'm assuming this is the wire that would send signal to tach?Took control box apart and tested grey wire inside and nothing.Any idea as what i can do next?
rancher00
Re: tachometer problem-1995 evinrude 88 spl
I just got a new tach. yesterday havent installed it yet the Instructions say " Johnson/ Evenrude 88-112 " Special " Models may require the addition of a 2000 ohm resistor or a BRP voltage regulator"
dieselcat
Dont think that would solve my problem cause i'm not getting any power from control box grey wire.
ezeke
Run a test wire from the engine terminal block to your tach and connect it in place of the grey wire. If the tach responds, you have a break in the harness wire or your rectifier is not working.
You must have the positive and negative wires from the ignition connected and the switch must be in the run position. When you first turn the key to run, the tach should snap to a zero reading if the - and + black and purple wires are correctly installed.
dieselcat
All other gauges work properly and the tach does go to 0 when key is turned on.But when i crank the motor and start it i do not get anything?
If the rectifier is bad,will the motor still run?
david_r
sounds like you reg/rec is out..........look in the faq's for the test procedure or your manual....the only test i have saved is the old rec test for the small round rec....this one is posted by spinnerbait nut but is written by joe reeves.....2 great guys.
http://forums.iboats.com/showthread.php?t=190638
if you have the small one this will work---i dont know about the one under the flywheel
david_r
i do believe when working correctly the grey wire should put out 9-11 v dc while running....if you are checking it with a mm.
if you have the round reg/rec you will fry it if you accidentally hook up the battery backwards.....even a spark (barley touched).......it might be the same with the newer versions i dont know.
dieselcat
I looked for the small rectifier and can't find it anywere.acording to the parts list i have the small 1,but i dont see it.i do not have a manual for this motor and i'm lost.can someone post a pic of where the rectifier is?
dieselcat
there is not a grey wire coming from rectifier.the tach is darn near brand new,and it worked fine with other motor just before i switched them.
dieselcat
Thanks everyone for your help,new rectifier on the way
