Fireman431
- Sep 17, 2007
- 4,292
2001 Mercruiser 7.4L MPI
Replaced the tachs last week. Both engine run great. Both tachs read 650 @ idle. Up to about 2000 RPM, they both read the same. After that, the port tach starts reading higher than the stbd. At 3300 on the stbd (which I'm pretty sure is dead-on), the port is at 4000.
I know there's a fine tuning screw on the back, but that seems a little more than fine tuning. Plus, they both are running fine until 2000 RPM.
Some things I've noted:
1) Both are on the proper pulse setting (double checked)
2) Both are brand new
3) Both are same style/type/brand
4) Engines are tuned and run great
5) Sync gauge stays even as long as throttles are in-line
Running the boat at speed to adjust the tuning screw while the dash is out isn't an option. Any ideas?
Thanks in advance.
Thanks in advance.
