TD has one driving him to drink
Lone Duck
Master Chief Petty Officer
Re: TD has one driving him to drink
27 minutes!!!!!!!!!!! and youve had toooo much to drink already???
what are you 110lbs?
you drinking liquid sterno???
but thats none of my business...rigth? ha ha ha
my mechanic would have solved that 50 hps problem two days ago
"its junk, buy a new one"
ha ha
bob
Yesher! I started in the cups durrhing my( hick) firsht posdd!
tashasdaddy
i have good pulse from the cylinder, i even pulled the plugs, and turn flywheel by hand, and got good pulse, and good flow with the fuel pump. pulled reeds, they are good, guts from the intake side looked good. going to pull flywheel tomorrow, see what's going on under there.
Silvertip, i did the primer test also.
i'm sure the carbs are good.
the owners BIL is a tech down state, i talked with him tonight, and he is stumped also.
cdoliver
Is there a possible spark or spark advance problem? Haven't seen spark mentioned yet.
JB
Okay, it has to be evil spirits.
Recite the Rubyat at midnight in your friendly neighborhood cemetery. Then send $5 to evilspirit.com, c/o JB at The Hideout.
That won't fix anything, but it will prevent further infestations. :)
kenmyfam
Wet plugs usually mean either no spark or no air with the fuel, or fuel and spark way out of sequence.
Has this motor reportedly run well and then this happened all of a sudden or is this an unknown motor to both you and the owner.
tashasdaddy
no history, it has never ran correctly for the present owner. he was an uneducated buyer.
kenmyfam
I think whipping off the flywheel and seeing what is going on is a good idea at this point.
Look forward to reading an update after work today.
Patate
Did you test the engine with fresh gazoline?
tashasdaddy
using my new tank, hose and gas.
bullbat
startin to sound like u need a match and some gasoline.........and the problem is solved!!! then just sit back and have more "rum than coke"
tashasdaddy
well, it is on hold till Monday, the intake gasket did not arrive.
Willyclay
TD, the waiting is gonna kill me! It's sounding more and more like an exhaust blockage since it spits gas out and will not throttle up. If it was a car, I would say plugged catalytic converter or collapsed muffler, BTDT. Did you ever get a pressure&vacuum reading? Hang in there, I know you'll whip it!
Lone Duck
Ya mean I have to keep drinking till monday? I have to drink , it's the only way I'll sleep. If I don't drink It will keep going round and round in my head. Sooo! I got to pass out to rest.:D Is under the fly wheel O K ?
tashasdaddy
did not get there, i just back off for a day, so now for 3 days. tomorrow i will be on the water.
tashasdaddy
Got Gasket yesterday, also got 14 stitches in my left middle finger. got helper coming today, to be my left hand.
bob johnson
ouch...sometimes it is best not to display that finger to tempermental folk!
get well soon!
bob
Lone Duck
Bet that 200 hp got a bunch of not to polite names.:mad: :D
