Re: Thinking of buying a F25?
Sounds like you should decide which one you want to buy. It sounds like you can choose eather a 03 F25 hp w/electric start, or a 98 Honda Bf 30 hp w/ electric start. I would first decide which one you want then you'll know which one you dont need to buy. Lets say that you decide to buy the 98 honda. Now you know that you dont need to buy the 03 F25. Or if you decide to buy the 03 F25, then you will not need to buy the honda. Once you decide which motor you would like to buy then you will not need to buy the other one. If you buy the honda it sounds like it has 5 more HP than the F25 as it has 30 HP which is 5 more than the F25. The F25 is a 25 hp motor and a 30 hp motor has more hp than a 25 hp one. Also you might want to keep in mind that 25hp is a little less than 30hp. If you were to buy the F25 then you will be getting a motor that has 25hp and that is a little less than a 30hp motor. It really is up to you though which one you choose. I have a yamaha and i love it. It has 115 hp and that is a different class of hp range than your F25, as the F25 has 25 hp. I like honda's also but like i said i love yamaha as well. So it all kinda comes down to which one you want to buy. Sounds like you could choose a 03 F25 hp w/electric start, or a 98 Honda Bf 30 hp w/ electric start. Good luck on choosing one.
