roberthedgepath
- Jul 29, 2007
- 3
2000 Optimax 200HP
Tilt and trim will not work at either the throttle or engine locations. Engine is in the down position.
When operating either switch, I can hear/feel the relays (3) clicking , but with no other response.
I disconnected the bullet connections bypassing the relays and straight wirring to a hot connection. I can get the motor to raise but not lower.
Should I be able to make the motor lower using a straight wire method and, does it make since that since I can raise the motor by striaght wirring, that the relays are bad?
Thanks,
Thanks,
