Re: Tilt Trim Pump Wiring
you may be able to save that motor. the cap is not waterproof so water has gotten into the armature area. take out through bolts, remove armature. get frame down to just metal frame and magnets. brush with ospho or evapo-rust until all the rust is gone. once all the rust is gone brush a light coat of ospho, count to 30, and wipe mostly dry with newspaper. and yes, it is important to use ospho or similar products. it contains conversion coating chemicals that react with top layer of iron to create a non-rusting protection layer. When ospho is done properly you can leave raw metal out in the rain and it won't show rust for a few weeks. let the ospho sit overnight to fully dry. the metal should have a uniform blue-gray appearance. prime and paint. if done fully and properly, that will cure the rust.
polish armature. inspect bronze bearings. if needed polish with dremel and very fine stone. wash all parts thouroughly. apply very thin coat of marine trailer grease to bearing surfaces. Avoid getting grease into brushes. reassemble motor.
apply new seals throughout. If you do not have new then use silicone sealant but do not fully tighten top screws. leave 1/2 turn to go. allow silicone to dry fully then tighten last 1/2 turn.
