Tilt/Trim
FISHINJUNKIE
I justed replaced brushes on motor and drained fluid but im not sure of what type to put back in,the tilt/trim motor is for a 115 IL6 yr 1976 i've been told to just put in reg. Non-Detergent 30w anyone know for sure Thanks
achris
More fish than mountain goat
Re: Tilt/Trim
That or normal ATF.... Your choice...
Chris..........
superwooter
Re: Tilt/Trim
yeah, i didn't learn that valuable piece of info until after i paid $15 for a single quart of hydraulic fluid from my mercury dealer. i felt like an utter tool when i discovered i could have spent $2.95.
Chris1956
Re: Tilt/Trim
The original oil specified was 5W-30 motor oil. SAE 30 is a bit heavier, and may not work in cold weather. ATF is OK as well.
Moody Blue
Re: Tilt/Trim
If you only drained the pump reservoir, there will still be "original" oil in the lines and cylinders. Probably not a good idea to mix fluids, so either refill with the same type fluid as was originally in there OR, drain the complete system then refill with the fluid of your choice.
FISHINJUNKIE
Re: Tilt/Trim
Good point Moody didnt think about that,and it was only the fluid in the reservoir that i drained not sure what type of fluid used originally.How do i drain out the old fluid in lines and cylinders Thanks for all the help Guys
achris
Re: Tilt/Trim
If it was honey coloured, it was 30W oil. If it was red, AFT....
C.........
