Time to get started on the starcraft resto.
GA_Boater
Re: Time to get started on the starcraft resto.
I think your S/W is fine also. After you remove the PO doo-doo you can see for sure.
Yes, those itty bitty nails are a pain.
So the transom ply is out now?
SigSaurP229
No because I ran out of time but it should be out in about 15 minutes tomorrow.
SigSaurP229
Ok so it has been four days not sure if everyone has been biting their nails or not but not much has gotten done I basically blew everything off yesterday. (Up to and including work).
I did start with this though. 400 lbs of rotten plywood and foam to the dump.
THen on to this
To here
SigSaurP229
Then went and bought all of this
And that is not even half of the supplies. BEFORE everyone panics that is NOT pressure treated plywood and the moisture content is ok for some reason the picture looks green.
I also purchased new carpet, paint, vinyl, gluvit, foam. I bought a new grinder, riveter, wrecking bar, and HVLP gun.
I power washed and wire wheeled the inside to get rid of all the old carpet glue.
Then I went and started prepping the outside for paint by removing all the old decals.
Which is actually one of the more challenging jobs to date. There is no thought to it just scrape then scrape some more.
dozerII
Looking good Sig, those decals can be a real bear to get off, good job.
SigSaurP229
Absolutely the trick is HEAT just enough to bubble the decal not enough to warp the hull (easier said than done).
SigSaurP229
As far as the floor goes 5/8" is going back in the transom is 3/4" ext ply. So Glen I noticed you used Spar over epoxy on your projects was there any reason why?
GA_Boater
You weren't slacking off, Sig. Got a lot done.
SigSaurP229
Oh I forgot to mention she got leak tested not one leak anywhere on her so that was good news.
nature1100
Wow that's awesome. Looking good. Wish I was that far.
BonairII
Are you going to use that foil backed foam for floatation? If so....it's the wrong foam.
dozerII
I just use Spar no epoxy. I figure the origional wood was in the boat for 30 years with no sealer, I put on three coats of spar and keep the boat dry and covered it will last indefinatly. Plus I have allergies to epoxy and glass resins.
ezmobee
Yep. Wrong foam. I accidently bought a big pile of that stuff for my basement finishing project (had it delivered) and had to schlep it all back and get the correct extruded stuff.
SigSaurP229
Sorry no updates for today I read everyone loud and clear on the foam issue, however I don't understand the difference as this is the stuff TVA has approved for dock usage for years.
No updates today because I was cleaning and organizing the shop for the hull flip coming soon.
Bob_VT
Looking good...... quick question....... do I see Pressure Treated wood among your supplies???????? It has a greenish tint.
BonairII
It was my understanding that that foam WILL retain water.
I'm sure the foam experts will chime in with a ruling on what foam is ok.
SigSaurP229
Hey Bob I checked and rechecked there is NO pressure treated wood in the supplies. That was check number one. :)
ezmobee
Many of our Starcraft boats had the white foam in them from the factory. So it isn't the worst thing you could use. However, it will waterlog eventually if left in water. If you take care of it and keep it covered, it will probably be fine. It's not ideal though like extruded.
SigSaurP229
So I can't get the 2" extruded foam locally. This boat stays covered all the time, and is not slipped (trailer queen).
