Timing
aggiekid
I rebuilt a mercruiser 5.0 MAG MPI, and looking for some directions on adjusting the timing. I found several ways of setting this but the engine still doesn't fire after several adjustment. I now have the engine at TDC, so wanted some thoughts from this forum. I previous had fuel pump issue that has been resolved. I also get sparks at the spark plug, so assuming it could be a timing issue. Please help. Engine serial number is -1a316544
alldodge
engine still doesn't fire (start)
If there is no backfiring then its not timing, your not getting any fuel. Should have about 43 psi at the rail
Have you bleed the fuel rail?
Bt Doctur
with MPI you install the dist at the mark in the dist body, there is no adjusting of the timing The computer does it all
aggiekid
I do have 43 PSI at the rail. How do I bleed the fuel rail ? Thx for the quick response.
aggiekid
Got it...I am going to work the fuel issue, and hopefully that will resolve this issue. Thx for the response.
alldodge
Bleed from the schrader valve on the rail. Turn key a few times till it gets nothing but gas.
Take a very small amount (teaspoon or so) of gas and dribble into the throttle body
aggiekid
That worked..I now have fuel in the railing. I am going to connect all exhaust, and out drive, and then try to fire the engine again. You guys are awesome !
