Cadillac-ack-ack
- Dec 1, 2017
- 104
First off, let me say with the suggestions from other about what should be replaced (all the bearings I was questioning about re-using or replacing were replaced) and with a Seloc manual, the power head is finished. New pistons, rings, all bearings seals and gaskets. A nice hone job and she turns freely with just the right amount of that "new engine piston drag".
The waterpump is next and I've got a couple of related lower unit questions. To re-state a little history from my very first intro. This engine was dads and had not run for a lot of years. Around 15 years ago I changed the impeller and changed the gear oil, fired it up and ran it on the lake just two or three times. As I recall that initial draining was a bit milky. Fast forward to now and the gear oil that came out was pretty much just oil. A bit dark grayish with slight traces of tan. I don't know if I should let sleeping dogs lie or attempt to get the lower housing off the upper part and re-seal. The same goes for the bearing head seal. That piece is pretty corroded an I don't want to get to the eve of destruction getting it off if not needed. The water pump seal will be replaced. Am I right in thinking these three places are the only areas water can get into the gearbox? And I'm wondering, since this motor has been stored on a stand for the past 15 years, would not gear oil leak out if there was a bad seal or joint? There is not even a stain or a hint of oil at either the bearing hub seal or the parting joint for the lower housing. - Pete
