I am working on a 30hp evinrude. Started out to replace water pump and thermostat because the tattle tale stopped squirting. When I pulled the lower unit I found a bunch of melted plastic on top of the water pump housing and the drive shaft has more on it almost preventing me from removing the shaft. Some of the plastic is inside the upper hole that the shaft slides through. It started running rough above idle so when I went to check I saw the tattle tale problem but I have no idea how long this was going on. Have I cooked it or can it be fixed?Also what is that plastic that’s melted? It looks like a plastic tube around the drive shaft.
