solar7647
- Apr 23, 2009
- 1,218
Re: too rich
I don't think your spark is the problem, is the spark blue or more orange? My experience with black smoke is burning to much fuel. I would say check you your fuel line for clog and you fuel filter, then put power to just pump to make sure your getting good flow.... Also take the flame arrestor off the carb and manually pump the throttle linkage so you can see the injectors in the carb and how they are squirting the fuel in. Also verify your air fuel mixture screw are set properly. Turn them all the way in till they stop, then turn them out one full turn them another half. Then start it up and see what you get. If your not getting a good air/ fuel mix ie to much fuel vs air could be the issue. Let us know what you find.
