Woodonglass
- Dec 29, 2009
- 25,929
Re: Transom Repair 1979 Century 3000
Very easy to mark up your pics, Just use Microsoft Paint. It's on Everyones PC. In the Accessories Folder. Lots of boats have partial stringers for deck support. Nothing to worry about. If the core samples don't show any signes of wetness or rot, seal em up and don't worry about em. Again, you should research the installation specs for your particular Outdrive and Make sure that your build your transom to match the required thickness specs for it. They must correct or the outdrive will not install correctly.
I would love to know how to draw and print on the photos as you have......very clear!
The thickness should not be a problem as their is the fiberglass wall of the transom about 5/16" then one piece of 3/4" ply (the X area), then a smaller 3/4" plywood layer doubled around the transom cut out.
It would be pretty easy to cut a piece of plywood that would inclued the X area and the two lower wings. do you think that would add rigidity?
I am turning my attention to the stringers now. I drilled some test holes and the wood in the exposed area (cased in fiberglass, shown in the two photos) seems solid. There was an 8" piece of 2x4 out at the extreme sides of the boat that was not enclosed in fiberglass. I presume these were there to have a place for the plywood deck to anchor on the outsides. Have you seen construction like that before? I thought there would be one continues piece of 2x4 running the whole outside of the floor of the boat, but I guess not. Any thoughts on this?
I would love to see a schematic of the framing from Century on this boat.
thanks for your expertise, I appreciate it!
