Re: Transom Repair 1979 Century 3000
I removed my fuel tank and found some more bad wood. The stringers to either side of the center 2 ft. seem solid. there is fiberglass tabbed 6 0r 7 inches up the side of the stringer that laps on to bare plywood between the stringers. There is foam about 2 inches thick against the hull bottom, then 1/2" plywood over that. the fuel tank is suspended over this open plywood. the plywood is wet and rotted. the underneath foam is wet. the stringer is dry and hard and isolated from the wet. it looks like I can just repair the center plywood on this part.
foam questions: where I have pulled the top decking off, foam fills the void. this stuff is sturdy. you can walk on it and it does not move! the way some of the decking is installed looks like they rely on this strength to help support the deck......is this the case?
there are some areas where the foam is bone dry except the very bottom against the hull it is damp. the foam might be wet 1/8 ". should this foam be pulled out also?
is replacement foam injected in like the original construction?
much thanks for help with this
Ed
I-Mike, yes some busy. my wife thinks the boat is the last priority. go figure?
this photo shows the fiberglass rolled from the rotted plywood up onto part of the stringer near the stern.
this next photo shows where I pealed back the fiberglass exposing the rotted stringer underneath!
next photo shows where the stringer gets hard all the way down.....can you replace the rotted part going back?
this next photo shows where the foam is dry....and where the foam was cut out and wood used to fill in and help anchor the deck.
this photo shows where the unprotected 1/2"plywood under the fuel tank was wet and rotted.
