transom saver
randy tanner
Hi, Everybody,
Just wanting to ask what is a few opinions in regard to using transom saver while just sitting in driveway between outings.
thanks
Skidz
Re: transom saver
My thoughts are the less weight sitting on the transom the better. I leave mine on all the time. Look at it this way, what can it hurt?
randy tanner
Re: transom saver
Thanks Skidz,
Thats what i was thinking, just needed someone else to give opinion.
enjoy your summer.
Triton II
Re: transom saver
Hmmm, I had to think about this one. My thoughts are that the transom saver is designed to stop the OB bouncing up and down while towing by triangulating the lower leg to the trailer. If the OB is allowed to bounce it creates flexing in the transom which will eventually cause problems. When stationary it doesn't really do anything - personally I just leave the OB trimmed down without a saver when the boat's parked. My .02 worth.
TII
randy tanner
Re: transom saver
thanks for the reply, I was thinking that the weight of ob would be taken away from transom and transfered to trailor while stationary should benifit transom by relieving stress ? Is there any reason being not vertical that would cause any concern in warm dry weather ?
thanks Triton 11
possum2082
Re: transom saver
if it's a sterndrive, then your bellows are not going to be happy.
Re: transom saver
Some folks way over-think things. If it is ok to use while bouncing down the road, logic says its ok to use while sitting in the driveway -- except of course as was pointed out -- if you have an I/O.
Triton II
Re: transom saver
... logic says its ok to use while sitting in the driveway -- except of course as was pointed out -- if you have an I/O.
Or your OB manual says to store in trimmed down position, when, in my case anyway, the saver doesn't fit.
TII
Evinbuck
Re: transom saver
As already stated, it can't hurt. That being said all transoms are designed to support the engine weight not to mention the torque produced while underway. Common sense dictates weight hanging from a pivot point produces stress points so the use of a transom saver will transfer some of the weight load. Obviously the transom saver was designed with the primary purpose in mind being to transfer road shock to the trailer as well as helping secure the motor better. It depends on your storing situation. I can't use it because my garage bay isn't long enough. Sitting idle it's just dead weight and I have no big concerns the transom will be affected yet still if you can use it, it does transfer weight load. No rocket science.
Re: transom saver
TII
Outboards should definitely be stored full down if there is any chance of freezing temps. If tilted up, water can be trapped in the water pump and prop housing and if it should freeze, can break things. That is not much of a problem this time of year but come fall, tilt it down.
