I've got an alpha 1 that I am putting back together. The manual says to adjust the trim limit so that the measurements from bolt to bolt is 21 3/4 inches. That is significantly less than what it was at when I bought it, and it doesn't look like the drive is barely above the trailer height, which is pretty scary low. Prior to my adjustment it was at least 24-25".
The trim cylinders say "powertrim xd". Are they not the factory trim cylinders? Is 21 2/3" the correct extension?
I'm looking at 4A-12 in the Alpha1 manual (Service Manual 6).
