Re: Trying to rebuild 18 hp Johnson
Yes the drive shaft seal measure's 1in outside. 1/2in inside and about 7/32 width. I don't really have a way right now to measure .188,but rough estimates puts .188 real close to 7/32. The hole that is left by the removed drive shaft seal is exactly double that .188 measurement. mm is as small as i can go the seal measures about 4 1/2mm and the hole left by the other seal is 9mm
The drive shaft seal from a 18hp from 1958 through to the 70s should be as follows:
Part number: 321788
Sierra Part Number:18-2032
Shaft: 0.5"
Bore: 0.999"
OD: 1.003"
Width: 0.188"
Prop shaft seal from a 18hp from 1958 through to the 70's should be as follows:
Part number: 313284
Sierra Part Number:18-2005
Shaft: 0.625"
Bore: 1.124"
OD: 1.128"
Width: 0.25"
Is this what you have?
