Velvo penta does on water
siego99344
At this point am willing to try anything I just want to get that boat on the water
alldodge
Start by checking for 12V at the coil when cranking
next filing the points and make sure they open and close as the rotor turns.
If no spark after this, replace the points and condenser
siego99344
Still no success compression was good on all cylinders, replaced points . Used dwell tool. Carburetor is getting fuel. But once I start cracking engine IN the lake it turns on but I can't put it in idle otherwise engine sputters and dies and I have to spray starting fluid inside carb to turn back on. 😫😫😫
alldodge
What was the compression numbers?
What is the idle rpm, and if its turned up does it still have the issue?
siego99344
Well after redoing compression test I got
2- 140
4 - 60
6 - 150
8 - 150
1 - 135
3 - 135
5 - 145
7 - 145
alldodge
Except for the one cylinder the numbers are good. Most likely a valve issue
The one cylinder should not cause it not to run in the water. What is your idle rpm, 600 ?
siego99344
Yea i was thinking 7 out of 8 isnt to bad but i would want to get that fixed hopefullyvjust stuck since it hasnt ran for 9 to 10 years and Roughly between 700 - 900
alldodge
If accurate 700 to 900 is more then enough to keep it going. Its a real puzzler
siego99344
Yea your telling me now am just part swapping. One friend told me it could be the propeller. But the people that had it before they parked it 10 years ago said it ran fine
alldodge
It could be the exhaust is mostly plugged up. It runs on land because there is no back pressure. In the water the exhaust builds up and is unable to be fully pushed out
siego99344
Is that the exhaust? Or where should I look
alldodge
That is where the exhaust exits, but look at the exhaust elbows and pies which lead to the drive. Like the bottom of the Y pipe
alldodge
Not so much there, but those areas can cause issues. The back side of the exhaust goes down to the drive in a Y pipe. Where the left and right side join together before it exits can get clogged if things drop down inside it
siego99344
Noted i will look into that when I get home
siego99344
The y pipe going down was no build up or anything in there looked fairly clean 😬😬😬
alldodge
If your compression gauge is accurate then motor is good enough to run even with the one low cylinder. I'm out of ideas
siego99344
Thank you for your help. I used 2 different gauges both read the same. Someone mentioned to me something to do with the propeller
CaptnKingfisher
Anyone have anymore ideas before I take it to a marine mechanic.
What was your procedure when you tuned the carb?
Other thoughts:
Inspect your fuel quality. I dump the gas out of my filter canister into a clear glass jar for inspection. Does it look like you've got good gas coming out of your tank?
Next run the boat for a minute and read the plugs after you shut it down. Plugs will tell us a lot.. plenty of guides online that teach you to read spark plug condition. Take pics or tell us what you find.
Those are my top two suggestions on where to start given the info.. but next I'd test ignition circuit components.
