Re: Volvo-Penta gear oil?
remove all three plugs- dip stick on top, fill level plug behind shift linkage, fill/drain plug behind props
drain all old oil checking for water and grit
you slowly fill from the bottom (behind the props) to avoid air pockets
fill till it comes out hole behind shift linkage cover
install all three plugs (top 2 first )
top off, if needed thru top dip stick hole
dp-s is 81 oz of Volvo Penta Synthetic Gearcase Lubricant
this info might be in the stickys up top in the vp section
If lubricant has been completely changed, oil level must be rechecked
after unit has been run and trapped air purged. Improper oil level will
result in serious internal sterndrive damage. Add make-up oil through
dipstick opening to bring oil up to proper level.
